rebuilding rear end ?'s
Old Mar 20, 2007 | 12:43 PM
leoni62486's Avatar
Default rebuilding rear end ?'s
hey guys, im thuinkin about tearing the 10 bolt to freshen it up....wondering if anyone out there makes like a rebuild kit or refresh kit or something wit hall the bearings and what not...more or less stuf better than the stock ones in there....if anyone knows of such kits or parts lemme kno...thanks..
also preference
richmond gears or motives???
any differences???
Old Mar 20, 2007 | 01:03 PM
BlackScreaminMachine's Avatar
Internet Mechanic
http://www.thunderracing.com/catalog...&vid=3&pcid=68
Complete Gear Swap Package
for GM 7.5" 10 Bolt Rear Ends
Thunder Racing has combined everything you need for your professional gear install...all in one convenient package!
MOTIVE Gears, in your choice of ratio...3.42, 3.73, 3.90 or 4.10
Or, STRANGE Gears (2 or 3 series carrier) for $35 additional
RATECH Complete Gear Installation Kit
2 Quarts RED LINE or ROYAL PURPLE Synthetic Gear Oil
1 Bottle GM Limited Slip Differential Additive
TA Performance Rear End Cover Girdle Engraved w/Thunder Racing Logo
TA Performance Stud Kit
http://www.thunderracing.com/catalog...&vid=3&pcid=67
Gear Installation Kits
Ratech, a leading manufacturer of race-proven small rear end parts, has several installation kits available for no-hassle gear installs or assembly of your rear end.
Basic Kit: Includes pinion shims, crush sleeve, pinion seal & cover gasket
Complete Kit: Includes pinion shims, carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts, cover gasket, and pinion & carrier bearings
Deluxe Kit: Includes pinion shims, carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts, cover gasket, pinion & carrier bearings, PLUS wheel bearings and seals. (All of the small parts and pieces necessary to RESTORE an axle to like new condition!)
Ratech also manufacturs solid pinion bearing spacers, or "crush collars." These are excellent for cars that "shock" their rear ends extremely hard during launching, which is common with manual transmissions. The solid pinion spacer will allow your rear end setup to remain constant after repeated hard launches. (Because this piece is setup slightly different than a standard crush collar, please ensure that your gear installer is familiar with installing solid pinion spacers.)
Get the Deluxe kit for 35$ more, which you order it with the 1st link, I just included the info on the deluxe install kit. Should be the hot ticket.
