Where can i find...
sorry i should have added, im going to a install 4.10 set. can i use the pinion bearing off my old 2 series 3.08 rear? or will i need a new one? thx!
If you are installing new gears, I HIGHLY recommend that you replace the pinion and carrier bearings at a minimum. Its cheap insurance... unless you want to replace the bearings in the near future. How near ?? Could be 5 miles could be 5000... but not worth the headache doing something twice.
You could use the old bearings for set up... tho...
The majority of the 4.10 installs (to include Motive, USGear and OEM) I have done were in at about 0.037". But... mind you... that would merely be a good starting point for you to consider. Every differential is a little different... so use that only as a guidline.
