broken 10bolt people
Old Mar 31, 2007 | 04:54 PM
patriotformula's Avatar
My lt1 formula broke shifting at WOT into 2nd (m6). Cracked the diff housing all the way around. Then destroyed everything else at the same time.
Old Mar 31, 2007 | 05:17 PM
LS1powerhouse02's Avatar
my car had 92,000 on the clock. 2002 Z28 cam only car M6. The rearend had apparently been rebuilt right before i bought it with a torsen and 3.73s. But it died after MAYBE 10 launches at the track leaving at idle with MT ET Streets. KABOOM!!
Brent
Keliente- What posi unit and gear ratio were you using when you lasted 250 passes?!?! And leaving at 5k? DAMN!!
Old Mar 31, 2007 | 10:15 PM
keliente's Avatar
It was a stock posi and I installed a set of 4.10s. It was nothing but sheer luck holding that bitch together!!! It didn't die until I put the mickey thompsons on. I knew I was asking for trouble It was just the inside of the torsen differential that let loose. I think the auburn is a better unit personally.
Maybe I just have a magic touch with setting up gears. I also put 3.73s into my boyfriend's supercharged formula M6 that made around 550hp. He beat on it pretty hard and it's still holding strong today even after going to the track and all.
Old Apr 1, 2007 | 12:04 AM
to-fst-4u's Avatar
kelly how many passes did your rear last on the MT's...mine lasted a whole one pass. i ran countless times on the BFG's with no troubles.
Old Apr 1, 2007 | 09:53 AM
keliente's Avatar
ONE
I left pretty hard and it made this AWFUL noise going down the track. By the time I got to the end, it was griniding and hopping and I thought the axle was going to just fall right out
Old Apr 1, 2007 | 11:14 AM
to-fst-4u's Avatar
ONE
well damn there you have it. the lift expectancy of a 10 bolt on MT's...a whole one pass. I at least got to make a full pass..then the next time to the line i didnt make it to the 60' box. damn its gonna be a long weekend at rockingham...try to baby it out of the hole i guess.
Old Apr 1, 2007 | 11:41 AM
what kind of tire were you running before the MTs? I need to get something a little less sticky if i want my now second 10 bolt to last a little while.
I'm debating between the BFGs or the Nittos. What do you think?
Brent
Old Apr 1, 2007 | 01:12 PM
Xth105's Avatar
1st rear @ 18K - don't remember what caused it
2nd @ 37K
1.81 60's
1500 rpm launch
stock converter
BOOM
Old Apr 1, 2007 | 02:22 PM
keliente's Avatar
Brent
I used street tires. I would 60' in the high 1.80's so I didn't really see the need for a drag radial, until the m/t's. I'd go with BFGs.
