What is "adjustable" about an adjustable master?
There's a new clutch in my near future and I've read dozens of posts about, depending on which clutch you go with, the need for the adjustable master cylinder. But NO where in these posts did it say what the damn thing is meant to adjust! Soooo...what does this thing do and why would I want one? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Clutches of old (cable style) always had a way to dial the throw of the cable in and out. That would preadjust the leverage required for the throw out fork. On the T56 for our cars there is no throw out fork, all of this is done hydraulically. As a result the tolerance stackup of the flywheel, clutch assembly and the slave cylinder from the back of the motor to the face of the transmission will vary greatly from vendor to vendor.
One way to solve this is to shim the difference in thickness between the slave and the transmission. But this is a pain in the ***, especially when it takes a good hour to put the trans in, let alone take it out.
As a result McLeod came out with the adjustable master. When you take the stock master you will see that it's a fixed length with no adjustments. The McLeod adjustable simply has a thread on the end with a ball swivel tie rod end. To adjust the throwout position and the sweet spot for engagement you simply turn the rod end. As a result the stroke is lengthened or shortend. Because it's all hydraulic the displacement of the fluid will cause the slave to move and take up any tolerance issues and slack.
It's really that simple. My opinion is that hydraulic clutches are a pain in the *** to service. But they are pretty damn good once you get over all those little details.
www.rapidmotorports.com
