Is this busted rear end?
Old Sep 28, 2002 | 03:13 PM
badls1's Avatar
Default Is this busted rear end?
Does anyone know where i could find a plug for the driveshaft hole. I have this loud rubbing like grinding hard. I wanted to pull the drive shaft out run it and see if the noise goes away. if it does then its not the tranny, busted rear end. if it stays its the transmission. I check everything is normal nothing rubbs on the driveshaft.
Is it possible the nose is being sent through the shaft to the tranny cause i could tell its sounds like the trasmission?
thanks
Old Sep 28, 2002 | 10:10 PM
wrencher's Avatar
wrencher
Default Re: Is this busted rear end?
Why not raise & support rear of vehicle & run car in gear & listen with a rubber hose to your ear & see were noise is coming from. Probably is the pinion bearings.
