Is there a diff between a hex head and a allen head?
Old Oct 2, 2002 | 09:19 AM
Gary's Avatar
Default Is there a diff between a hex head and a allen head?
They are both six sides?!?! I got some bolt sizes, and they were stated in both hex and allen types.
Old Oct 2, 2002 | 10:31 AM
nthnwbr's Avatar
Default Re: Is there a diff between a hex head and a allen head?
A hex is a standard bolt, you would use a wrench on(external hex). An Allen is a bolt you would use a Allen wrench on(internal hex).
Old Oct 2, 2002 | 10:34 AM
Gary's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by nthnwbr:
<strong>A hex is a standard bolt, you would use a wrench on(external hex). An Allen is a bolt you would use a Allen wrench on(internal hex).</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Explain this to me then: <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
From Rob Moser on T/A performance cover:
The bolts on the performance covers are as follows:
Cover Bolts, Main Cap Load Bolts, and Drain Plug - 1/4" allen head
Fill Plug - 1/2" allen head
Nuts on Load bolts - 3/4" hex head
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">- The socket set I got from Home Depot (to fit inside the bolts like an allen wrench) are called Hex heads. So basically there is no difference..
<small>[ October 02, 2002, 10:51 AM: Message edited by: Gary ]</small>
Old Oct 2, 2002 | 11:01 AM
2xLS1's Avatar
Hex head when referring to a wrench = allen wrench style.
Hex head when referring to a bolt = 6 or 12 point head requiring a open end/box end wrench, or socket.
Old Oct 2, 2002 | 01:26 PM
Fulton 1's Avatar
As the others have pointed out - generally an allen head bolt/screw will be a cap screw with an internal hex (i.e. requiring an Allen wrench to install/remove). A hex head bolt would be one that has your standard 6-point head. A double hex would be a 12-point. These would require your standard socket or combo/open end wrench to install.
Here's a link showing different nuts and bolts and stuff, which may help clarify: http://www.absofast.com/
Old Mar 6, 2016 | 10:46 AM
ajaxbolt's Avatar
Default Ajaxbolt and nut manufacturer and distributor of hex and stud bolt
You can find further information about bolts and nuts and the standards on the following website
ajaxbolt
ajaxboltco
Old May 16, 2017 | 08:05 AM
Ali Alirezaee's Avatar
You can find further information about Air Curtain and the standards on the following website
FarazKavianCo
FarazKavian
Old May 16, 2017 | 08:06 AM
SteelPichCo
SteelPich
Old May 16, 2017 | 08:13 AM
01ssreda4's Avatar
Holy 15 year old thread!!!!!!!!!!
Old May 19, 2017 | 08:14 PM
_JB_'s Avatar
Spambots digging up **** lol.
