top speed with a 4.10?
Old May 2, 2007 | 02:37 PM
rekless's Avatar
Default top speed with a 4.10?
im thininking about getting a 4.10 to replace my stock one but im a little concerned about top speed...what do you guys think?
Old May 2, 2007 | 02:49 PM
Cchris1109's Avatar
do 3.73s youll hate yourself if you g et 4.10s in an auto
Old May 2, 2007 | 02:52 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Run the calulator....
http://www.f-body.org/gears/
using 6000 rpm limit, 3.23 OR 2.73 gears, 26" tall tire
*edit* found some ratios.....
1st 3.06
2nd 1.75
3rd 1.00
4th 0.70
with 3.23 144mph @ 6000 in 3rd
with 4.10 113mph @ 6000 in 3rd
A good bolt on car will be nearly maxing out his rpm, you may need a taller tire or extend the rpm
On a side note 4.10's are going to be a bit much.
Ace$nyper's Avatar
Use the gear ratio sticky and find out exactly.
If you are auto 4:10s will really turn on the highway. Most people rather 3:73s.
Old May 2, 2007 | 02:55 PM
Ericbigmac83's Avatar
go with 3.73's
