Solid ponion spacer questions
Old Oct 9, 2002 | 02:45 PM
RJF's Avatar
RJF
Default Solid ponion spacer questions
Hi Im gettin ready to install a set of SLP 3.73 gear. And I was reading up on makeing the 7.5 10 bolt last for awhile. It said to use a solid pinion spacer in place of the crush coller. How does that work. Is it the same thickness as the crush collar or will it have to be filed to the pinion dept? Im not sure on how that works. Any help would greatly appriciated. Thanks
RJF
Old Oct 11, 2002 | 05:30 PM
RJF's Avatar
RJF
Default Re: Solid ponion spacer questions
ttt
Old Oct 12, 2002 | 01:12 PM
jmd's Avatar
jmd
The solid spacer comes w/ shims to adjust its depth. Used the ratech solid one from Thunder...
Matthew
