Is there a reasonably quiet 9" or 12 bolt? (LONG)
Old Oct 11, 2002 | 04:31 PM
Silver Slayer's Avatar
Default Is there a reasonably quiet 9" or 12 bolt? (LONG)
Ok, does anyone have a 9" or 12 bolt in an F-body where the noise is tolerable? My Moser 9" sounds like one of those old air raid sirens and the noise gets louder the more load it is under.
I sent the third member back to Moser once, and the guy I talked to then said they switched the U.S. gearset to a Richmond gearset, and they replaced the bearings. When I put it back in, after about 75 miles, the noise came back. I called back and talked with someone else, and he said that there was nothing in the notes about changing to a Richmond gearset.
The guy also told me that putting an aftermarket rear in an F-body was guaranteed to make noise, there was no way around it.
I know I should expect some noise, but I can barely hold a conversation and my ears are almost ringing when I get out of my car. You can even hear the noise if you are standing on the side of the street when I pass by.
I have had some people tell me that it is possible to get one that is quiet and others that say you can't.
Do I need to go to a 12 bolt? Is it possible to have one that is tolerable?
Any opinions appreciated, sorry this was so long.
Thanks,
Kevin
Old Oct 11, 2002 | 07:38 PM
GeorgeC's Avatar
Default Re: Is there a reasonably quiet 9" or 12 bolt? (LONG)
The problem is that you're having Moser set up the gears. You'd think they would know what they're doing, but I know of lots of folks that could never get a quiet set up from Moser.
I have Richmond 4.33 gears in my Moser 9" and they are dead quiet, even after the horrible abuse I've put them through. They were set up by a shop here in Florida.
Old Oct 12, 2002 | 11:05 AM
GeorgeC,
Did you get your 9" from Moser? Did you have to buy a new gearset?
Thanks for the information,
Kevin
Old Oct 14, 2002 | 11:52 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I had the same experience as George, and I returned my Moser 9" centersection and installed a used third member from a mid 9 second car and i was pretty quiet.
Old Oct 14, 2002 | 01:53 PM
FEAR THE LS1's Avatar
I bought a Moser 12 Bolt with 4.30 gears from Raging Motorsports. It was drop shipped from Moser to me. I had it installed by my mechanic. My rear end is dead quiet. It makes no noise at all. I was running a 10 bolt with 4.10's and it whining really loud.
I know the more you race on your rear end the louder it will get, but I already have about 15 passes on my new rear and its still perfectly quiet.
Lee
Old Oct 14, 2002 | 03:30 PM
WILWAXU's Avatar
Another trick is to stay away from poly mounted control arms. My Strange was quiet till I added poly/poly control arms.
Old Oct 14, 2002 | 04:33 PM
GeorgeC's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Silver Slayer:
<strong>GeorgeC,
Kevin</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Initially yes. I got the rear end with 3.70 gears. Since I can't leave anything alone, I've also had 3.50, 4.11, and the current 4.33's in it. The current gears were bought new and installed by a competent shop and remain quiet after ~1.5 years.
