Help with gear swap
Old Oct 12, 2002 | 08:02 PM
Terry Burger's Avatar
Default Help with gear swap
I'm attempting my first ever gear swap. I've got the axles out and main caps off. How to I pop out the differential? Do I just pry it with a pry bar? Is there a hidden bolt I'm missing?
Thanks,
Old Oct 12, 2002 | 09:31 PM
Gag_Halfront's Avatar
Default Re: Help with gear swap
(moving to transmission and gearing...)
It's a custom fit, alright. <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
Might take some fighting to get it appart. I suggest investing in a thesauras of swear words. The usual and customary combinations and incantations you already know may not be enough to persuade it.
Old Oct 12, 2002 | 10:19 PM
Dom's Avatar
Dom
This might help you.
www.geocities.com/d_payton1/gearinstallation.html
Old Oct 13, 2002 | 12:08 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
http://www.sethirdgen.org/10bolt1.htm
Here's another link that may help. FYI when I do gears I use a 3/4 wrench on a ring gear bolt to lock down the carrier against the housing (topside), then use a prybar to turn the carrier. With the wrench locking down the carrier, the only way for it to move when turning is out.
Old Oct 14, 2002 | 01:38 AM
taqwache's Avatar
if it is realy tight you could use your prybar to lock the diff and use your ratchet and turn the pinion. once the prybar hits something and stops then by turning the pinion it will force it out. this works great because the lower gear ratio cut into the gears provides you with 3.42 (or what ever you gear ratio is) times the turning force of a similary lenght prybar. so if your ratchet is 1' long then it is equal to useing a 3.42' prybar on the diff. then if you add a cheater bar and get up to a 2' ratchet now your talking like a 6.84' prybar. anyways hope that this helps.
