Master Cylinder problem!
Old Apr 26, 2003 | 04:28 PM
Loudmouth LS1's Avatar
Default Master Cylinder problem!
I think I need an adjustable master, cuz my clutch pedal has absolutely no pressure, and it is not fully engaging cuz it slightly grinds before going into gear. There is nothing wrong with the clutch, cuz it was checked while my tranny was out being rebuilt, so i'm assuming it has to be the master. I have a Mcleod Rev-Lok II revised edition, and I was wondering if this Adjustable master would work and would solve my problem cuz it's a hell of a lot cheaper than the mcleod and i'm kind of strapped for cash after my tranny build up! Thanks in advance for any info guys!
http://www.paceperformance.com/subca...315&2=1106
Old Apr 27, 2003 | 04:18 AM
Default Re: Master Cylinder problem!
Anybody have any suggestions?
Old Apr 27, 2003 | 08:24 AM
Slowhawk's Avatar
LS1Tech Sponsor
Here is something to try.Get a vacuum bleeder.Use a fitting to go into the resivor line tightly.Pump up to 20"'s of vacuum and have someone push the peddle 1/2 way down.This should pull the air out of the master.
E-mail me for more details.
Old Apr 28, 2003 | 02:18 PM
Do you think it's a problem of just not being bled correctly (or enough)? Cuz I had everything professionally done, and the reason I was thinking it was the master going bad was b/c i'm on the stock gm '01-'02 master, not an adjustable. Let me know what you think, if it is that it's not bled right, i'll try it again. Thanks
Old Apr 29, 2003 | 01:05 AM
Well, I talked to Mcleod today, and he said with my symptoms that he thinks it needs to be bled, that there is probably air in the system. And as for that Ram adjustable master, I contacted Pace about it, and they said it should work, just in case anyone else was wondering about it.
