shift points
Old May 18, 2007 | 04:31 PM
BurtReynolds's Avatar
Default shift points
I had 2.73 and moved up to 3.73.How should it be? Also how far should I raise the rev limiter.I was thinking to 6200.I will be installing the ls6 cam in a few months.
Old May 19, 2007 | 12:22 AM
Travis99LS1's Avatar
You will definately like the 3.73's..i just went from 2.73's to 3.42's and i love it. The rev limiter is already set at 6200 stock. Just changing gears has no relation to how far the motor can rev safely. I would leave the rev limiter alone until you install the LS6 cam, different pushrods, and better springs...than you could safely bump the rev limiter to 65-6600.
Old May 20, 2007 | 02:45 AM
00slowredz's Avatar
i went with a custom cam and i still have to play with my shift points. but you will definitely love the 2.73-3.73 swap, its a huge difference. if you did the valvetrain work with the cam, 6600 wont be a problem at all. i took mine to 6800 and it wanted to keep pulling but i dont really wanna spin it that much....
Old May 20, 2007 | 06:17 AM
cowboysfan's Avatar
yup! changing gears has nothing to do with shifting point. you want to shift where it will keep you on the power band. as for rev limiter I would not go higher then 65k/68k with stock bottom. I got my limiter set at 6800, shift light at 6300 cause when light comes on and my reaction to shift is at different rpm's. so by checking my data I'm shifting at 6600 sometimes 6700.
