Question about changing wheel studs
My first night out with slicks and I managed to break a wheel stud while trying to take the slicks off the following morning.
I've got a Strange Dana S60, 4-channel backing plates (3-channel ABS and 3-channel rear end), and the stock size (12mm x 1.5 pitch x 1.75" length) wheel studs. I'm going to replace the stud with the same size.I've taken the wheel off, and the only way I see to get at the wheel studs is through the hole where the ABS sensor goes in these 4-channel backing plates, but it doesn't look like there's any way I'm going to get a socket in there on those hex heads. So, I have the following questions for you...
1) This is the most important one to me... do I have to take the axles out to get at these damn things, or is there an easier way?
2) What studs do you guys recommend? I don't want to spend the money on ARPs since there appears to be holes for 1/2" studs in the wheel hubs. I'll upgrade eventually, but I'm currently trying to minimize the cost. Summit has some studs made by Gorilla that look like a good buy price-wise.
3) Am I to assume that since there is a hex head on these things that they're screw-in and not press-in studs?
Thanks in advance everyone. I sure hope I can get this all figured out by this weekend! I've got some guys at work talking trash about LS1s, and I need to show up and wipe the floor with 'em.
1) The studs are screw-in, not press-in.
2) The hub has holes pre-drilled for 1/2" studs.
3) The backing plates have to be removed to get at the studs, but you don't need to pull the axles out more than a few inches to get the studs out.
Anyone recommend a brand of hardened screw-in axle studs?
