LCA Relocation Brackets???
Old Apr 28, 2003 | 09:21 PM
BoneStock's Avatar
Default LCA Relocation Brackets???
Ok I just installed the Eibach Pro-kit and now I'm in the process of installing these weld in brackets. There are two sets of holes that the control arms can bolt into. My question is, which holes do I bolt my control arms to?
Old Apr 29, 2003 | 07:00 PM
Viper's Avatar
Default Re: LCA Relocation Brackets???
I went with the lowest hole. A friend tried both, prefered the lower.
Old Apr 30, 2003 | 09:13 AM
Fulton 1's Avatar
You want to try and get the LCA's parallel to the ground or slightly lower at the rear. This meant the lowest setting on my BMR brackets with ProKit springs.
Old Apr 30, 2003 | 11:03 AM
Cal's Avatar
Cal
The lower holes are best for accelerating, the upper holes are best for braking . . . if you get chattering, you are using the wrong set of holes.
Old May 1, 2003 | 01:07 PM
LS1Bird's Avatar
Go Low!
