blown motor...does that equal bad trans???
Old Oct 21, 2002 | 05:30 PM
Slow Z28's Avatar
Default blown motor...does that equal bad trans???
Well, at the track the other weekend, i blew what i thought was the motor and the trans. Well, i thought it was the trans as well because of the redish fluid on the ground under the car. But when i drained the oil out of the pan before i removed the oil pan, the same color liquid came out of the oil pan. so i'm guessing that's the coolant because the coolant that was in there is a redish color. So, could it be possible that the trans is ok? Still shifts through the gears, if that's worth anything. Still rolls when pushed. No clanking in the trans when it's being pushed.
Chris
Old Oct 21, 2002 | 06:40 PM
Colonel's Avatar
Default Re: blown motor...does that equal bad trans???
Sounds like the tranny's fine to me.
