Help!!
Old May 1, 2003 | 07:55 AM
1MEANSS's Avatar
Default Help!!
Ok I have no idea were or what this could be comming from,but when I leave out of first gear there is a slight squeek comming from the front to middle of the car right before the clutch is fully disengaged after that it's fine no noise nothing, I put a spec stage 3 clutch in about 1,000 miles ago, but I don't think that would have anything to do with it????? Pleas help I'm so confused
Old May 1, 2003 | 08:21 AM
trackbird's Avatar
Default Re: Help!!
Is the noise coming from under the dash? There have been several squeaky clutch pedals mentioned on the board. If it is under the car, is there any more info you can give us?
Old May 1, 2003 | 08:27 AM
1MEANSS's Avatar
Default Re: Help!!
It happen's when leaving slow out of first gear, but if i dump the clutch or leave out fast it won't make that noise, I'm sorry I can't explain it better but I'm so confused and don't know were it could be comming from.
Old May 1, 2003 | 08:30 AM
1MEANSS's Avatar
Default Re: Help!!
also I pretty much now it's not the clutch pedal just for the fact that it's not coming from inside the car??? I'm stumped...........
