noise from a aftermarket shifter?
Old Oct 23, 2002 | 04:58 AM
ls1snakebiter's Avatar
Default noise from a aftermarket shifter?
which shifter makes the most noise between the pro 5.0 and the B&m ripper? i know the pro 5.0 u have to cut the boot how does it work wit the ripper.
Old Oct 23, 2002 | 02:50 PM
LOnSLO's Avatar
Default Re: noise from a aftermarket shifter?
I would say you have to cut the boot with the Ripper also. I have the Pro 5.0. It was noisy as hell for about the first 300 miles, but now it's almost as quiet as the stock Hurst POS.
Old Oct 23, 2002 | 03:50 PM
RTCamaroSS's Avatar
My Ripper is pretty noisy, has been since day one. When i switched from the stock ball **** to an SLP ****, the noise went down a lot... The name of the game is insulation... Notice if you take the **** off, there is NO noise... I found that putting a few thick rubber bands around the base area of the stick itself (under the leather boot), helps out a bit.. it helps supress some of the noise.
Old Oct 24, 2002 | 11:48 AM
Rayo's Avatar
I installed the Pro 5.0 without cutting the boot at all...and I also did the Rob Mod for the Lou's Short Stick...used some locktite on the stick bolts...and I have no noise whatsoever...I recommend that you do not cut the boot...that way noise will be minimal if any....
Old Oct 26, 2002 | 12:22 AM
Lance's Avatar
I did the same...not cut the boot...but the rubber
band idea is neat...I will add that to my setup.
