Vibration at 75+mph
Now this vibration is not anywhere close to as bad as it was with my stock shaft but I have found that if I drop the vehicle in neutral at a speed where vibration is present the vibration stops. as soon as I put it back in gear it comes back.
Is it my driveshaft causing this or my tranny?
anyone else that can confirm it?
You -could- have a trans. issue at 60, and then a driveshaft balance issue starting at 70mph, with OD hiding the trans. issue, but I'd start chasing this down at the trans. Slip yoke seems to be taken care of; take a look at the tailhousing bushing.
Matthew
Matthew
Could this be the problem?
