Drive shaft length, is this correct?
Old Jun 7, 2007 | 02:43 PM
LS1_Fonzie's Avatar
Default Drive shaft length, is this correct?
I'm going to be upgrading to a Strange 12 bolt and I was told I can use a stock size drive shaft. I will be upgrading to a new drive shaft but wanted to be sure of the measurements I took. From the trans case to the flat surface on the pinion yoke I measured 44 3/4 inches. The shaft exiting the housing measured 13/18 inches, close to 3/4 inches . Thats the one I'm unsure of. I'll be ordering from SJM Manufacturing and used their site a guide to find my measurements http://www.sjmmanufacturing.com/cam_dt_ls1.html# The 12 bolt I will be getting is Part#: STR-PRG210 and the drive shaft is Part#: STR-U1702. Thanks.
Old Jun 7, 2007 | 05:19 PM
Ws6 Love's Avatar
well i ordered mine from moser and im using my stock driveshaft and it fit fine, but there is a lil play, but i called them and they said thats normal..
Old Jun 7, 2007 | 07:54 PM
2 fast 2000's Avatar
Yes the stock driveshaft size will work. Your suppose to use the stock size anyways. Never heard of any custom length with the 12 bolts.
