stock master made adjustable pics
Old May 7, 2003 | 04:08 PM
MIGHTYMOUSE's Avatar
Default stock master made adjustable pics
just for you guys, i took my backup master apart.
notice the metal cone thats cut in half to allow for extra piston travel
again, cut the eye off the end of the stock shaft and then another .25" or so and thread
the threaded part (cast part not gold rod) is a 3/8-24 die and you install a 3/8-24 female spherical rod end to that.
only thing after that is to grind down the ball in the rod end itself until it is narrow enough to fit into the peddle bracket.
http://community.webshots.com/album/64999662fXYdvY/1
i have had absolutely no problems with this setup, i run a spec stage 4 fyi. its a 0277 master and i run a 5145 slave
Old May 7, 2003 | 09:28 PM
buschman's Avatar
Default Re: stock master made adjustable pics
Looks good Dave. I always wondered what the inside of those things looked like. Thanks for posting up.
Mike
Old May 8, 2003 | 01:16 PM
rodent's Avatar
Good info! I might try this on a 95 master I have laying around.
Old May 8, 2003 | 03:13 PM
pirate3's Avatar
Excellent. T hanks for posting that info and pics.
