C-Clips ??
Old Nov 2, 2002 | 11:24 PM
RJF's Avatar
RJF
Default C-Clips ??
ARE THE C-CLIPS DIFFERENT IN 2 SERIES AN 3 SERIES 10 BOLT CARRIERS. CAN'T GET THE ONES FROM THE 2 SERIES CARRIER TO FIT DOESN'T LOOK POSSIBLE.ANY TRICKS?
Old Nov 3, 2002 | 10:44 AM
Dave Carney's Avatar
Default Re: C-Clips ??
They are the same. Been there, done that. What do you mean they won't fit? You can't slide them over the axle or??
Old Nov 3, 2002 | 11:06 AM
RJF's Avatar
RJF
THANKS FOR REPLY! IT SEEMS THAT THE AXLES WON'T SLIDE IN FAR ENOUGH TO BE ABLE TO SLIDE CLIP IN AXLE GROVE. WITH AXLE OUT CLIP FITS AXLE GROVE FINE.IT ALSO FITS IN CARRIER SLOT.AXLE SEEMS SHORT.
Old Nov 3, 2002 | 11:49 AM
You need to remove the tcs pickup sensor thing if you have one and the brake backing plates first or the axle won't slide in far enough.
Old Nov 3, 2002 | 11:54 AM
PS: you have the retainer out of there right? It's a metal block for torsens or a cylinder for auburns...
Old Nov 4, 2002 | 11:22 AM
RJF's Avatar
RJF
DAVE THANK YOU VERY VERY MUCH! YOU HIT IT RIGHT ON THE HEAD.CHECKED OUT WHAT YOU SAID, AXLES THEN SLID IN FURTHER LETTING CLIPS GO RIGHT ON. YOUR THE MAN! THANKS AGAIN RONNIE
Old Nov 6, 2002 | 12:01 AM
Great! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
