Line Lock help
Old May 10, 2003 | 01:38 AM
ssdungeon's Avatar
Default Line Lock help
OK all I have is a line lock silinoid. I was told that I only needed a toggle and a momentary switch. I need anyone to give me breif or email me some instructions on how to install it. I really need it installed... I will be redoing my exhaust next weekend anyway so that would be a good time to get everything I need and Make it happen...
1> Is that all I need?
2> Any instructions? I did not figure on it being very hard but I have no idea.
Thanks guys and gals,
Old May 10, 2003 | 12:22 PM
trackbird's Avatar
Default Re: Line Lock help
You will need some brake line and fittings (and a double flaring tool) to allow you to "splice" the solenoid into the front brake lines on your car. It needs to hold pressure on both wheels at the same time (or you will be doing circular burnouts...). YOu may find someone on here with a set of SLP instructions that they can scan and send to you. Ths SLP will be slightly more relevant to our cars instead of a generic set (like from hurst, etc) Just my thoughts. Good luck!
Old May 11, 2003 | 03:41 PM
ROB'S SS's Avatar
whos line lock is it anyways? thunder racing sells an install kit for the hurst line lock, ans slp sells an install kit for the slp line lock
Old May 13, 2003 | 02:01 AM
ssdungeon's Avatar
Morosso is the brand.
Thanks,
