Fourth gear gets stuck!
Old May 10, 2003 | 12:56 PM
ssdungeon's Avatar
Default Fourth gear gets stuck!
Either my 3/4 syncros are bad or maybe low on fluid. I am not sure how to bleed the thing but because I have no problems in any other gear I am saying its probably the syncros. D&D has an upgrade for the 3/4 and fork for $49.00 is that all I will need? I am also trying to find out if I need to get the bearings also they are 199.00. I have had the syncros redone in the car at GM several times and now I see there is an upgrade from D&D If just 4rth gear gets stuck, no popping out of third or slipping could the 3/4 syncro be all that I need?
Thanks,
