12 Bolt Rear End Question
I dont beat on the car a whole lot, nor am I making enough power to kill the HD Posi that i know of. Only thing ive done lately is put DR's on it, but even then, i havent sat there doing burnouts or driven all that differently. I find it kinda hard to believe the posi is dying from pretty much nothing. I will be taking car in to have rearend drained and to take a look for metal shavings. Then put some new fluid and see what it does following.
Any ideas what else to look into? Any help or comments are appreciated. Thanks
With a tight clutch pack and the tire slip associated with modern, harder durometer street radials... I wouldnt think you'd hear the clutch chatter to begin with. The new DR's just plain hook... and I'll bet the clutch chatter is related to the amount of friction modifier in the base oil. You may need to run just a little bit more to take the chatter out of it. With the lube change, you'll need about 4oz of fric mod.
