Pinion angle questions
Old May 12, 2003 | 07:03 PM
Scalpel's Avatar
Default Pinion angle questions
What is it? What should it be set at for a street car at stock ride height? What affects can improper pinion angle cause?
Old May 12, 2003 | 10:39 PM
trackbird's Avatar
Default Re: Pinion angle questions
I'd stick to -.5 to -1 degree for a street car and not much more (if any more) than -2 degrees for a drag car. To much pinion angle (-3 or more...give or take) can bind the u-joints in the driveshaft and cause vibrations, worn U-joints and if bad enough, damaged driveshafts. GOod luck!
