NEED HELP!!!
Old May 13, 2003 | 01:37 PM
SWEET98SS's Avatar
Default NEED HELP!!!
I have a 98 ss with the m6. Ive been having some problems with the clutch pedal sticking to the floor. It does this even when I am just driving slow and go to shift. It also goes into gear hard when it does this.Im pretty sure it is the hydraulics. I was planning on upgrading the hydraulics and putting a new clutch in it. Im not sure what kind of clutch to go with. I was thinking maybe the star spec II clutch. I dont planning on doing any power adders maybe a cam in the next couple of years. I was looking at www.hpaparts.com. the spec II is $370 then i was planning on getting the hydraulics from ls1speed. Any suggestions....
Old May 13, 2003 | 08:39 PM
wrencher's Avatar
wrencher
Default Re: NEED HELP!!!
That sounds like a plan, common problem on these.
That should work fine with a mostly stock set-up.
You will be happy with the new set-up.
