screeching noise from rear???
this happens occasionaly and it doesn't seem related to turning or not.
any ideas what could be going on???
Torsen for GM vehicles:
Is it true that the Torsen unit in the production Camaro needs the GM modifier added?
GM issued a technical bulletin adding modifier to the rear axle oil. This was done to quiet what we call a "Rusty Screw" noise that we heard in a very small percentage of vehicles. This does not happen in all cases, however to address owner's concerns we asked that the modifier be used in all instances to insure that the driver would not get this noise. When replacing the fluid it is at the owner's discretion whether or not to add the modifier. Elimination of the modifier does not affect durability of the differential.
http://www.torsen.com/general/genera...difier%20added
i have the additive in there.
so i guess i'll try and check the swaybar bushings and the re check my pinion angle.
