another noise question
Old Jul 22, 2007 | 03:49 PM
99345hp's Avatar
Default another noise question
Ive got another rear end noise question for you guys. I have a stock rearend with 4.10s. The car had never had stickies on it, or drag raced. It is a M6. It makes a whining noise only while decelerating in gear, and while turning. But it only makes the noise while turning left, no noise at all while turning right with the clutch in. It seems to be worse with 2 or more people in the car. Im thinking its Axle bearings, because those are the only things that weren't changed during the gear install. The wear pattern on the gears is fine, so I dont think that is the problem. What do you all think? Bearings or could it be posi??
Old Sep 18, 2007 | 05:37 PM
bigwillie's Avatar
Did you ever figure this one out? That sounds like what mine is doing now. I was thinking bad posi, but I don't know much.
Old Sep 20, 2007 | 09:30 AM
highwaywonderland's Avatar
bearings might be bad
