using of dial indicator (rearend)
Anyway, that one inch travel dial is connected to a magnetic base. The dial and base have what is called universal swivel clamps. This allows you to place the magnetic base on a flat surface such as the machined housing face you see in your pic. With the swivel clamps you position the tip of the indicator stem on the face (side) of one ring gear tooth. As you can see, the indicator is near the outer edge where free movement would "show" the most easily. One inch travel dial indicators with a magnetic base and swivel clamps are so incredibly inexpensive compared to the days when I was buying my machinist tools. Something like $40 gets you a nice set-up. I paid 3 times that 35 years ago when a $5 hourly wage considered good money.
