9" axel setup
Old Jul 31, 2007 | 06:51 AM
yak's Avatar
yak
Default 9" axel setup
what is the axel setupo for ls1's on a 9"? reluctor ring, backing plate, bearing? then the bearing presses into the case too?
Old Aug 1, 2007 | 02:54 PM
helicoil's Avatar
Default 9"
Basically, yes. Bearing into housing is not really super tight, I guess you could call it pressed
Old Aug 1, 2007 | 05:33 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
Axel=......AXLE..... ........... Just letting you know, so it will NOT happen again...
