Need gear advice
I'm thinking about going to a 3.73 gear and was wondering what everyone else's experience has been especially anyone with a similar setup. What all is involved with having the gear installed and will the car need to be tuned again or does the pcm just need to be adjusted for the spedo ?
The car is running fairly consistent 12.30's@109+mph with 60ft times in the low 1.7's. How much of an effect will this have on my ET and mph ?
Will the gear help get the car off the line any quicker ?
Looking at a few runs I have data logged it appears I'm going through the traps at about 5400rpms. The 2-3 shift is also pretty consistent at 6300rpms. The 1-2 seems to vary from 6200-6400.
Thanks!
any steeper, and well, you start to make sacrifices!
I would say with a good launch and those 3.73's, you'll gain a tenth or two EASY....
As far as calibration/tuning goes, just have someone hook up HP tuners and change the gear ratio setting in the PCM so the speedo is correct!
GOOD LUCK!
Erik
