Amount of fluid for a moser 9" change?
Old Nov 21, 2002 | 02:28 PM
MacGyver's Avatar
Default Amount of fluid for a moser 9" change?
I've got a moser 9" with a locker and 4.11 gears. Anyone know how much fluid it takes? And what kind should I use. I bought some mobil 1 75/90 but I dug up a couple of old posts that say not to use synthetic. Thanks for the help
Will
Old Nov 21, 2002 | 02:53 PM
Fireball's Avatar
Default Re: Amount of fluid for a moser 9" change?
~4 quarts
Old Nov 21, 2002 | 03:41 PM
MacGyver's Avatar
Are you sure it's that much. I called moser before you replied and they said that it varies by the size of the case but it would probably be around 3 quarts.
Will
Old Nov 21, 2002 | 05:14 PM
Paul F's Avatar
I pretty sure mine held almost 3 quarts. Not a hundred percent sure though.
Paul
Old Nov 21, 2002 | 06:48 PM
Fireball's Avatar
mine took more than 3 qts. I remember the install sheet saying it'll need 4 qts. I think mine took 3.5 or so
Old Nov 21, 2002 | 08:32 PM
cenman's Avatar
2.5
Old Nov 22, 2002 | 10:27 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
2.5-3, so just get 3 qts.
I run like 85/140 dino.
