Does Tire Diameter Effect Dyno Readings???
Old Nov 23, 2002 | 05:27 AM
purple bandit's Avatar
Default Does Tire Diameter Effect Dyno Readings???
All things being equal if you dyno the same car with a 26 inch tire, and then with a 25 inch tire would the dyno readings be different? Would the shorter tire give higher dyno readings?
<small>[ November 23, 2002, 08:49 AM: Message edited by: purple bandit ]</small>
