worth a little chuckle
Old May 22, 2003 | 01:48 PM
ROCKWS6's Avatar
Default worth a little chuckle
Just thought i'd post this 'cause it cracked me up. had service bulletin done on rear differential and the gm gear oil proudly advertises a "new grape scent" on the bottle. as if that isn't goofy enough, the warning label on the bottle says it's vapor harmful. so by putting the grape scent "ad" on the bottle, you get 100% more people to actually take a sec. to take a sniff...????? is it just me or is the whole planet losing it??
Old May 22, 2003 | 06:18 PM
Roadrunner 45's Avatar
Default Re: worth a little chuckle
that's the best - lol
Old May 23, 2003 | 08:14 AM
NHRATA01's Avatar
Hehe, well I guess GM is being nice, and figure when you blow a hole in your 10 bolt POS, at least you'll be treated to a nice grape aroma.
Old May 23, 2003 | 09:39 AM
Viper's Avatar
If you've ever smelled normal rear end grease or had it on you, you will appreciate the grape smell. The normal smell will make you want to retch!
Old May 23, 2003 | 03:43 PM
00z's Avatar
00z
i ruined a whole load of laundry because of my work clothes that had rear end fluid in it. it smells like cat ****
Old May 23, 2003 | 09:00 PM
trackbird's Avatar
GM would like to ask when was the last time you desided to "stop and smell the gear oil".
They know that we were upset that they killed the F-body and they are trying to eliminate us....one technical service bulletin at a time......
Old May 24, 2003 | 01:48 PM
ynneK's Avatar
you know, I didn't believe it...
but I searchd and found it on ACDelco's webpage
Part 10-4016
88900401
Synthetic Rear-Axle Lubricant
SAE 75W-90
Fully synthetic
Superior oxidation and thermal stability
Long-life fluid
Grape scent
http://www.acdelco.com/html/pi_vehcare_lub.htm
Old May 24, 2003 | 02:14 PM
BIG PD's Avatar
i like the smell of rear end oil...does it smell bad to most people?
