Pinion Angle help please....
Old Nov 24, 2002 | 06:00 PM
Johns98Z28's Avatar
Default Pinion Angle help please....
Okay I know this is a hot topic, but according to BMR and Spohn(which is were I got my Torque Arm from)this is how to measure your pinion angle: pinion angle - drive shaft angle = true pinion angle. So according to that formula here's my numbers, tell me if I have this right please.
This is measuring from the driver's side,
Pinion Angle: .5* to the right of the 0
Drive Shaft Angle: 2* to the left of the 0
So that's: -.5* - 2* = -2.5* right?
On the pinion: the #'s to the right of the 0 are negative right? That would be the pinion pointing down to the ground.
On the Drive Shaft: the #'s to the left of the 0 are positive right? That would be the drive shaft pointing down towards the rear of the car.
TIA for any help and/or replies.
Old Nov 24, 2002 | 07:51 PM
cenman's Avatar
Default Re: Pinion Angle help please....
here's the real way to set it up. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
http://www.rosslertrans.com/Tips/Pinon.htm
Old Nov 25, 2002 | 05:29 PM
Johns98Z28's Avatar
Old Nov 25, 2002 | 05:33 PM
BADZ's Avatar
Moderator
nice info....
