need some suspension help
Old May 22, 2003 | 08:31 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Default need some suspension help
for all that have a 12bolt rear I have some questions. Ok I want to check everything in the back that connects to the rear. Like what angle should the LCAs be with the weight of the car on them? Also do yours feel like it has really heavy springs in the back if so know any fixes for it? I also want to check my torque arm angle and see what I have to do there. Any help would be great.
Old May 22, 2003 | 09:19 PM
Viper's Avatar
Default Re: need some suspension help
Well, regardless of whether it's a 9", 12-bolt or 10-bolt you want the LCA's parallel to the ground when it's sitting. What springs are in it now? Shocks, tires, swaybars? ALL of those pieces act in concert , and any one of them could cause a 'heavy spring' feeling. As far as the torque arm angle, is it stock? If not, is it adjustable? Basically you need a magnetic angle reader. I had one given to me, but it's basically a small piece so you can place it on the driveshaft etc.
Hope this helps; we need more info from you.
Old May 22, 2003 | 09:49 PM
Cool28's Avatar
I have hals shocks stock springs stock lca and stock torque arm thats adjustable. Tires are stock 16in rims with stock size tires on it.
Old May 22, 2003 | 11:47 PM
Cal's Avatar
Cal
The 12 bolt rear itself is a heavier piece than the stock 10 bolt and adds to unsprung weight. That may be what you are noticing.
Old May 23, 2003 | 06:33 AM
Viper's Avatar
Yes, effectively changing the rate of the spring.
Old May 23, 2003 | 09:13 PM
trackbird's Avatar
It really can't affect the actual spring rate, but it can increase the load placed on the shocks and springs causing a change in ride characteristics. The shock has the job of damping the axle motions and stiffening the compression valving on the shocks will likely restore (or increase/change) the ride quality and some handling performance. A slightly better statement would be:
Effectively changing the demands placed on the spring and shock and possibly the requirements of the shocks associated with that spring.....
Old May 23, 2003 | 10:15 PM
trackbird's Avatar
But....I guess I am that ****....sorry (I'll try to fix it....I promise)....
Kevin
Old May 24, 2003 | 07:11 AM
Viper's Avatar
And don't run more than 30 maybe 32 in the rear tires (is stock size). That severely ups the spring rate in the tire and hurts it's road compliance.
The above is from Sam Strano.
Old May 24, 2003 | 10:24 AM
Cool28's Avatar
ok I just checked my lcas and if there pose to be lvl they are not by far. they go up to the rear as it sits outside now. I know I have a 1in rake from front to back but the lcas dont follow the angle of the car. Culd that be my problem? almost looks like I need relocation brackets.
