What kind of rearend is this
Old Aug 11, 2007 | 01:09 PM
crz28's Avatar
Default What kind of rearend is this
My 1995 camaro lt1 has a currie 3rd member and currie axles, now is this a 12 bolt or 10 bolt , how can i know
Old Aug 11, 2007 | 01:25 PM
styoung's Avatar
if it has a 3rd member its a 9in, is the back of the diff smooth?
Old Aug 11, 2007 | 01:28 PM
crz28's Avatar
Yes it is smooth
Old Aug 12, 2007 | 02:27 AM
revtime's Avatar
The guy you bought it from didn't tell you it had a 9 inch in it?
Old Aug 12, 2007 | 05:46 PM
00PewterSS's Avatar
Sounds like you fell into a deal. You'll have to figure out what was done to it. Is it an LT1 still? What did you buy it for?
Brian
Old Aug 15, 2007 | 10:52 AM
crz28's Avatar
i took this pics when we put the energy suspension bushing kit , i took the car in for 4k ,its a 1994 camaro lt1 m6 , i bought it , had a tune up done to it at my buddies shop and after looking at it he tells me that the car is cammed , so i got curious cause i already felt that the car was pretty stong, so we went to dyno the car and it pull 365rwhp, recently y just added a 100 shot of juice and it put down 475rwhp so i'm a really happy guy right now.
Apparently it has a cc306 cam a act stage 3 clutch lingenfelter cai , also the rotors on the back brakes seem to be bigger than the ones in front
Attached Thumbnails What kind of rearend is this-dsc00566.jpg   What kind of rearend is this-dsc00567.jpg   What kind of rearend is this-camaro1.jpg
Old Aug 15, 2007 | 12:19 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
That stock case is only good for high 10's at best.
Old Aug 15, 2007 | 12:26 PM
crz28's Avatar
This diff has currie axles they have a pink stamp when you take the hub of the wheel , so is this 10 bolt or 12 bolt
Old Aug 15, 2007 | 07:04 PM
Duffster's Avatar
that Sir, would be a 9". . .
Old Aug 15, 2007 | 07:21 PM
Formula_Power's Avatar
so you paid 4k for an lt1 with a nine inch/cam and who knows what else...and it put down 365 on motor to the wheels even though the power robbing nine inch...i think is safe to say you did pretty good since the rear end alone would be worth 1500 at least
Old Aug 16, 2007 | 10:06 AM
crz28's Avatar
Why is the 9in a power robber,
Old Aug 16, 2007 | 10:17 AM
1969NovaSS's Avatar
It takes a little more power to turn the 9 inch then a 12 bolt.
Old Aug 16, 2007 | 10:34 AM
Ericbigmac83's Avatar
I'll trade you my 10 bolt so you dont lose that power to the rear wheels.....dont wanna lose any power.......
Great find, sounds like you got a great car for the price
Old Aug 16, 2007 | 10:57 AM
XpEdItIoUs's Avatar
I paid $2,500 for my moser 9", You got a good deal on that car.
Old Aug 16, 2007 | 10:58 AM
XpEdItIoUs's Avatar
If you get a aluminum center with a spool it should weight as much as a 12 bolt with a posi.
Old Aug 16, 2007 | 12:07 PM
408z28's Avatar
I would rather lose 5-10 rwhp, than break a 10 bolt everytime I went to the track.
Old Aug 16, 2007 | 02:55 PM
mzoomora's Avatar
14 Second Truck Club
Its not just the weight of the rear and components that adds to driveline loss, the 9" has its pinion in a different location relative to the center of the ring gear which make it less efficient at transferring power.
That being said, I also would rather know that it is 10x harder to break and give up a few hp.
Old Aug 16, 2007 | 09:15 PM
WS6 SRT-8's Avatar
Do you have any pics of the torque arm mount?
Old Aug 17, 2007 | 02:16 AM
LS1Tech Sponsor
I've seen 12 bolts puck the spider gears out in 11 second cars. I've installed a few 9 inches with the same ratio's the customer was running in the stock 10 bolt and the cars picked up ET at the same mph. Average is .30 in the 1320 so IMo the 9 inch is the most versitile assembly out there. There are more ratio's and diff's to choose from.
