Transmission woes
Old May 23, 2003 | 01:35 PM
Scream's Avatar
Default Transmission woes
I'm having some weird tranny issues! At times, the truck doesn't want to downshift. If I manually select a lower gear, it's fine.
I was having a whole lot of SES codes when I did the cam, and I was told by some local LS1 buddies that the SES light can foul up the converter's functions, so I thought that might be the culprit. But, now that the idle is better, I'm only getting the Misfires code every now and then, and it usually goes out very shortly. Last night it did it again, and there was no SES light.
Anyone have any ideas? What steps can I take to correct this problem? Rebuild? 4L65E? Lightning? (j/k)
