Will the 10 bolt be ok
Old Aug 16, 2007 | 02:22 PM
wanting_ back_a_ss's Avatar
Default Will the 10 bolt be ok
I have a 99 z28. I dont know what gears are in it right now. I just had drag radials put on it and need help getting it off the line now. I don't want to go with a stall. Im trying to save up fo the new camaro's when they come out so money is a issue. I have a set of motive 3:73 gears already. If I had Bob install them at exotic performance plus along with a EFI Live tune will the rear end be ok? Also how much will that help me out of the hole?
Old Aug 16, 2007 | 02:26 PM
GrahamHill's Avatar
The rears are set to go at any time. But with an A4 and stock converter you can get by with a little more although she'll launch like a slingshot with an aftermarket converter to go along with those 3.73's AND drag radials
Old Aug 17, 2007 | 11:20 PM
BriancWS6's Avatar
The stock 10 bolt can live for a while in an A4. Since your not modded much, and don't have a higher stalled verter, you should have an even better chance of it living for a while.
Old Aug 18, 2007 | 09:30 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The time in my sig was with a cam, 150 shot, 3K converter and used 3.42s. Like the others said the Auto cars are easier on the 10 bolt. Mine even had a ring gear spacer in it. You should go ahead and get a 3500 stall converter and run mid 12s
Old Aug 19, 2007 | 02:25 PM
billybadd's Avatar
Make sure your suspension is set-up decent..... wheel hop kills 10 bolts faster than anything. Good luck.
