LT1(383) and PY3400 problems
What was the weather like when you pulled 1.69 with the stock converter vs. when you pulled the same time with the Pro Yank? That could make some difference.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Thanks for your help
May be too much stall. If peak torque is at 3400 and a low stall stock unit is netting good 60' (never seen a 1.69 on a stock converter before) a 2800 - 3000 stall is a better a solution than a ST 3500.
A TT2800 might work better. It is a larger diameter converter and should stall around 3000 behind your motor.
I had the same 60's with 3.23s and 3.73s and nothing else changing, but the ETs dropped a good bit b/c of the Revs on the top end.
To me it sounds like you need a different TC, I would personally vote for the ST3500.
What PCM are you running? OBDI or II or aftermarket? If you are running OBDI, realize you might have a limp home problem with the high stall and brake stalling. I never had the problem unless I was brake stalling. The OBDII cars dont have this problem.
I will also add that stalling mine up vs leaving off idle produced the same 60's.
