Gear swap
Old Aug 24, 2007 | 12:04 AM
NBM99SS's Avatar
Default Gear swap
Well since my 4.10's are about to come apart, and I dont have money for a 9 inch yet I am planning to put the 3.42's back in for the time being. I bought a cheap install kit from summit with just the shims, pinion seal, and crush sleeve. Im not worried about the bearings and stuff. I have a solid pinion spacer in now and was wondering if I should reuse that or use the new crush sleeve? Also can I use the same pinion shims for me pinion depth or do I need to reset it?
Old Aug 28, 2007 | 10:48 AM
PONYEATER's Avatar
you can use the solid spacer again but you will need to check your pinion depth.
