Eaton Differential
Old Aug 27, 2007 | 12:21 AM
JGA's Avatar
JGA
Default Eaton Differential
Re 98 Camaro
Should I use synthetic or regular GL5 with posi fluid? What oil weight should I run. Any help much appreciated.
Thanks
PS its a limited slip with clutches.
Old Aug 27, 2007 | 04:03 AM
chicane's Avatar
Regular... with 4oz of friction modifier.
I like to use a straight weight 140 for performance builds, but a good 85-140wt will do just fine.
Old Sep 23, 2007 | 07:50 PM
jonm3456's Avatar
Default the use of synthetic fluid in eaton LSD
i mistakenly used Royal Purple Synthetic Gear Fluid with my Eaton Posi. I went to the track and was only doing one wheel peels for burnouts. I guess that when you use synthetic with the carbon clutches in the Eaton it wipes them out. This week i am going to inspect and rebuild my posi...
