10 Bolt Chatter, Fluid level/Type? Question?
Maybe chicane, or some of our other resident diff experts will comment on this??
If you dont see any clutch plates... my money is on that it is an Auburn limited slip. Torsens dont really chatter, so to speak... so Ill leave that out of the equation for now. But an Auburn, or an Eaton will... if there is no (or not enough) friction modifier. Even if the fluid itself comes with friction modifier in it.
But... 99% of the time, when you change the differential fluid and you pick up a chatter, howling or popping when turning... its due to a lack of friction modifier or not enough of it. You will not pick up chatter when accelerating in a straight line thou... that kinda has me puzzled... but in the turns, it is totally suspect.
I... would squirt another 2oz or so into the differential to start off with. If that doesnt work... add the last 2oz. If THAT... doesnt work, I would use something other than Mobile1 for fluid. I have never... had to use more than about 4-6oz in a passenger car differential... but have had to in DANA60's and/or larger differentials due to their fluid capacity.
And yes... I too... will recommend the use of a 75/85-140... as a standard for performance use.
