Making the 10 bolt stronger?
Is it possible to make the 10 bolt stronger. I'm thinking maybe 400rwhp, stall and tires tops. Thanks. -Mark
Oh and this is on the wifes 01 A4.
I would say do nothing at all to the 10 bolt. Leave it alone, and when it breaks, go right to a 12 bolt and forget about it. Even if you buy every aftermarket thing for the 10 bolt, you still could do something like twist the housing, then you've got $1k into a rear you can't even use.
Using a solid pinion racer helps, as does as a TA cover and using a stronger diff like the T2R ($600). And not launching on slicks. Mine has survived with the above at well over 400HP for 7 years now. Drag radials for 7 years too, launched as high as 4K.
save up for a 9" and use your 10 bolt til it break, because they arent as weak as people say. I used my 10 bolt on nittos for 1.5 years an it never broke and I went 8.0s in the 1/8th all day and it ate less rwhp, weighed less and gave mezero problems, whereas the 12 bolt from day 1 have given me problems as well as many more that came along.
Strengthening The Rearend From An LS1 Firebird Formula - Maximum-Effort Fourth-Gen10-Bolt
Follow that, and you will have the most bullet proof 10 bolt possible (which isn't saying all that much). So if you break that, then you know its time to step up to a 12 bolt or Ford 9".
I think that article should be a sticky somewhere
I don't know about you guys, but I don't have a lot of extra cash to spend. I'm not going to pour money into something that "might" work.
Besides, $1300 is more than half the cost of the aftermarket rear. And that's parts only - if you can't do your own labor that's another $300-$400 you'll have to add.
The deals are out there you just have to have the money and wait till they come along.
And I whole heartedly agree that you should not even think about wasting money on the 10 bolt.
