replaceing wheelstuds on a 12 bolt
Old Aug 30, 2007 | 09:50 PM
d-1sc408's Avatar
Default replaceing wheelstuds on a 12 bolt
i have a moser 12 bolt what is needed to be done to replace and where do i get the studs
Old Aug 31, 2007 | 05:18 AM
EPP's Avatar
EPP
You need to first see if you need threaded wheelstuds or pressed in wheel studs. You can tell by looking at the studs where they pass through the axles. ARP makes wheel studs in all common sizes. Stock wheel studs for our cars are a 12 mm, and you need to know if you need 12 mm or 1/2 wheel studs, then figure out what length you want to go to. Bob
Old Sep 9, 2007 | 01:18 PM
d-1sc408's Avatar
do i have to pull the axel out
Old Sep 12, 2007 | 06:44 PM
BadBandit69's Avatar
i didn't have to pull the axle out to get mine out.
Old Sep 13, 2007 | 10:43 AM
Steve Burger's Avatar
LS1TECH Sponsor
I would upgrade to 1/2" studs will you are at it. YOu will need to pull the axels and have them resized for the 1/2" studs. At your HP level it's a smart thing to do.
