6 speed conversion
YOu will need the correct flywheel, clutch, transmission, bellhousing, torque arm mount, crossmember and pedals and hydraulics and a center console from a manual.
YOu will pull the transmission, flywheel, and converter.
YOu will swap in the new parts after drilling the hole for the hydraulics in the firewall and bolting them in place with the new pedals.
The hard part will be pulling the neutral safety switch wires out of the auto shifter and hooking up the clutch switch. You will also need to hook your cruise control "cut out" switch to the clutch pedal as well as the brake. YOu will need to hook up the reverse lockout solenoid on the transmission.....many guys hook it to the brake pedal (since you will usually be stepping on the brake when shifting into reverse). I'm sure there are a few things that I may have missed, but basically, that is the bulk of it. I can't tell you if you will need to use LS1 edit to change the programming or not.....can anyone else help out? GOod luck!
