Moser 12 bolt question
Old Sep 6, 2007 | 08:46 AM
1hotls1's Avatar
Default Moser 12 bolt question
I recently did some tranny work and while the car was on the lift and in neutral, I tried turning the driveshaft and there was a good bit of resistance from the rear. It also shudders sometimes when backing up and I was just wondering if this is normal? I've had it about a year now and no issues til now, but the pinion seal leaks a little sometimes. Other than changing the fluid, any other recommendations?
Old Sep 8, 2007 | 04:51 AM
EPP's Avatar
EPP
I'd first make sure your rear brakes aren't hanging up, as it sounds like that could be your problem. Bob
Old Sep 8, 2007 | 12:00 PM
1hotls1's Avatar
Thanks. I'll check it out. I had a problem once with the e brake hanging up.
