Need a decent replacement 10 bolt.
Hey guys. Long story short, 250 miles after a General Motors rear end service on my 17,000 mile 02 SS 35th Anniv LE/M6, the car broke the pinion shaft, destroying the driveshaft, differential, housing, ring gears, and a lot of other crap. GM had a regional engineer look at it, and he conveniently decided that it was not their fault, that we ran it out of fluid (If someone could explain how this happens at 17,000 miles with not a drop of fluid in my garage I'd love it). The warranty company then decided that they still think it was GMs fault, so they won't pay for it either. I took the car to what I thought was a reputable differential shop, and $4800 later, I have my car back. Kind of. It's needed to go back every week for the past month because it still isn't half the car it was when I bought it at 12,000 miles. It's had 4 different diffs in it since.
The stock differential was the SLP Auburn yellow spring.
First he put in a SLP differential. This one howled like crazy, so I brought it back and he ordered an Eaton differential for it. Eaton sent the wrong one, and the right one is on back order. So then he put in an "Auburn Gold Series." As of right now, I don't know who to trust. Is this differential as good or better than my stock Auburn?
The car is a stock 345hp car, and it won't ever be modified, and probably won't ever see the track. Will this differential handle the factory power though the 275 BF Goodrich tires? If not, what's the best 10 bolt I can run?
