gear change in 10 bolt
Old Sep 8, 2007 | 01:14 PM
redramair98's Avatar
Default gear change in 10 bolt
i can think of 4 or 5 seperate people that had gears installed in there cars, one was even a firebird, and in every single one instance, the pinion gear had teeth taken off of it, is this a common problem i guess when putting gear sets in a 10 bolt? just trying to make a good choice on what to do 9 inch or just do my gears,
Old Sep 8, 2007 | 01:27 PM
02 wife's Avatar
I added 3.42 aam gears in my Camaro in Nov '05 and no problems! Its all about the installation and the break end period!
Old Sep 8, 2007 | 09:48 PM
jonm3456's Avatar
I would put gears in instead of 9"/12bolt. Aftermarket gear sets are very strong, when installed properly there should never be a gear tooth problem. The only way that the teeth will get chipped/broken is if the backlash on the ring gear is too tight. I am on my second set of 4.10's right now in my 10 bolt. When the first ones were installed the bearing caps were installed backwards and it spun a bearing on my posi ruining it and the gear set. Any more questions feel free to send a pm.
