help with motive gear
Old Sep 8, 2007 | 07:26 PM
rob scott's Avatar
Default help with motive gear
ok im looking to buy a set of 373 tonite and i seen speed inc has motive 373 gear for series 2 i just wanted make sure im reading this right and i dont need the spacer to run these. heres what is list ..
http://www.ls1speed.com/catagory.cfm.../%20Driveshaft
MOT75373X Motive Performance Gear Set 3.73 (2 Series Carrier) $189.99
i just want to make sure from someone else other than me before i order the gear that it is series 2 carrier because i havent seen any series 2 motive gears... but i dont get to actual look them up because of class and work. any info would be great because i want to place the order as soon as i know there series 2
Old Sep 8, 2007 | 07:36 PM
ChocoTaco369's Avatar
Tech Resident
If you have stock 2.73's and thus have the 2-series carrier, as long as the gears say they're for a 2 series, you don't need the spacer.
Just a heads up. but EPP has Motive 2 series 3.73's for $159.99.
http://www.exoticperformanceplus.com...html?item=1008
Here's the install kit:
http://www.exoticperformanceplus.com...html?item=1009
$85.99 is a good price for it. I paid $99.99 from Speed Inc., but I wanted 3.42's for my 2 series carrier and EPP didn't offer 2 series 3.42's. I got a set of Richmond's from Speed Inc. and they shipped a Motive install kit with it. Note that Speed Inc. has free shipping, so make sure you try the order with Speed Inc. and EPP to see what has the best price after shipping.
Note that the install kit on EPP says for 93-97 LT1 f-bodys, but since they shared the same rear as the LS1 cars, the install kit should work with 98-02 cars, also. If you're unsure and don't wanna take my word for it, you can always call
Old Sep 8, 2007 | 08:25 PM
rob scott's Avatar
thanks for the info and the heads up on the price. i will be placing my order shortly with epp
Old Sep 9, 2007 | 01:53 PM
Tech Resident
No problem, glad to help. If I were you, I'd call and order instead of doing it online for two reasons.
1.) Just to put your worries at ease that you're getting the correct gears for your car
2.) Bob at EPP is a great guy from what I've seen and heard
I'm sure online orders are fine, but if you feel uneasy, call them.
